It is currently Fri Aug 08, 2025 8:14 pm
 Post subject: Fingerboard removal
PostPosted: Wed Aug 23, 2017 9:46 am
First name: Jonny
Last Name: Fifield
Hi Folks
I have a few necks that I want to save the truss rods from.
What are some methods that can be used to remove the fingerboards(Titebond)from the neck?
"Practice enough till the results aren't hopes but expectations" forum member Peter Havriluk
 Post subject: Re: Fingerboard removal
PostPosted: Wed Aug 23, 2017 9:59 am
If you don't care about the fretboard, pull those frets out, put an iron on a slightly damp rag or paper towel, and have some fun. The heat and moisture will release the glue. Just separate it with a knife.
PostPosted: Wed Aug 23, 2017 10:35 am
An iron ON the frets will also heat the glue enough to loosen it. Most wood glues start breaking down around 180 degrees. Just work your way from one end to the other.
These users thanked the author Chris Pile for the post: Imbler (Wed Aug 23, 2017 10:42 am)
PostPosted: Wed Aug 23, 2017 10:42 am
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Thanks, I was wondering how they released the neck extension when doing a reset,
PostPosted: Wed Aug 23, 2017 1:31 pm
First name: Jonny
Last Name: Fifield
Is the water a must or will it just help it along?I guess what I am asking is can I remove it dry?
PostPosted: Wed Aug 23, 2017 1:46 pm
Some people use special sized heating blankets as well, no water really needed
PostPosted: Wed Aug 23, 2017 2:14 pm
First name: Gary
Last Name: Leddington
I did this recently to make a non accessable truss rod accsessable... just place an normal cloths iron atop the frets and work your way down with a pallet knife.
G.
www.leddingtonguitars.com
PostPosted: Thu Aug 24, 2017 11:25 am
First name: George
City: Seattle
Since you brought up the fingerboard extension area: As when removing a bridge, be mindful that runout can lead your pallet knife to dig into the top, as opposed to skimming the surface. I try to keep my knife at a 45 degree angle, switching from one side to the other (bass and treble), without crossing the center seam. Done properly, the piece will release gently, leaving the top nice and tidy, ready for scraping and easy clean up. Once the fingerboard extension is clear, I slide a piece of paper beneath it to prevent the glue from grabbing as I work my way up toward the nut.
George :-)
These users thanked the author George L for the post (total 2): ernie (Fri Aug 25, 2017 8:22 am) • Imbler (Thu Aug 24, 2017 11:34 am)
PostPosted: Sat Aug 26, 2017 11:41 am
I find leaving the frets in actually help conduct the heat to the bottom of the board, where you want it. I have custom-sized heat blankets that work, slowly, but find that an iron works faster.
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Sat Aug 26, 2017 8:56 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
A nice sharp axe would be the fastest way
Ed
PostPosted: Sun Aug 27, 2017 12:23 pm
But controlled removal would be great practice!
PostPosted: Sun Aug 27, 2017 1:39 pm
Using a 250 watt heat lamp and cardboard shield lined on the out side with foil, shiny side out/up is pretty common these days. Never leave it unattended.....
What I really wanted to comment on is that jumping through your sphincter to remove a fret board is not good practice for much of anything. In the world of professional Luthiers removing a fret board is very few and very far between with even decades going by never needing to do this.
If you enjoy disassembling guitars to recover parts go for it but this is about as useful a learning experience as sawing off a dowelled on neck and resetting it. It will never be done on a time and materials basis by a pro because the economics are not there.
PostPosted: Sun Aug 27, 2017 2:59 pm
You got that right, Hesh. I know an instructor who has been at Red Wing for a long time who turned the neck of a 60's Les Paul into charcoal because he went home for supper and forgot until about midnight. He lucked out..... no one ever came to claim the axe because the client was old and passed away.
These users thanked the author Chris Pile for the post: Hesh (Sun Aug 27, 2017 9:04 pm)
PostPosted: Sun Aug 27, 2017 7:01 pm
First name: steve
Last Name: scarborough
State: arkansas
Zip/Postal Code: 71822
I take a chisel and split the neck from the back. Then throw the neck away and keep the fretboard and truss rod for future projects
Sent from my 5054N using Tapatalk
Users browsing this forum: Ken Lewis and 33 guests
